configure esrp delete master
configure esrp esrpDomain delete master vlan_name
Description
Deletes the specifies master VLAN from the specified ESRP domain.
Syntax Description
esrpDomain Specifies the name of an ESRP domain.
vlan_name Specifies the name of the master VLAN.
Default
N/A.
Usage Guidelines
You must disable the ESRP domain before removing the master VLAN. To disable the ESRP domain, use the disable esrp {esrpDomain} command.
If you attempt to remove the master VLAN before disabling the ESRP domain, the switch displays an error message similar to the following:
ERROR: Failed to delete master vlan for domain "esrp1" ; ESRP is enabled!
If this happens, disable the ESRP domain and re-issue the configure esrp delete master command.
The following command deletes the master VLAN purple from the ESRP domain esrp1:
configure esrp esrp1 delete master purple
This command was first available in ExtremeXOS 11.0.
Platform Availability
